21 - 29 of 29 Posts
Nice reading, thanks for the link. Still no answer to my question, the article only compares Ethanol to Heptane to ISO-Octane, it does not compare flame burn rate vs fuel types, completely ignoring gasoline. Instead the test only compares flame propagation rate changes for each of those above listed three fuel types at different mixtures. The simple result: Fuels burn faster initially then slow down over time from ignition with rich mixtures, and fuel burns slow initially and increase burn speed over time from ignition with lean mixtures.
I wonder why no one has any articles comparing the burn rate of differnt fuel types? I think there is some missing information that might show a disadvantage of the politically motivated fuel strategy we are being pushed into.
Isooctane is gasoline. Gas is made up of all kinds of things with isooctane being the primary indgredent
Gasoline starts from fuel distilled from crude oil, processed to remove some harmful chemicals inherent in the fuel, mixed with other chemicals (including ISO-Octane and a slew of others) etc... to produce the final product commonly referred to as 'Gasoline'.
I guess there is no standard for what exactly Gasoline is...
Because the burn rate of fuel(s) is only a repetitive constant when they are ignited under the same conditions. When it comes to engines the burn rate--aka flame travel speed--its different from one configuration to another. As an engine builder, I do many different things and use different parts to increase or decrease the flame speed to fit a specific application.
The information you seek is in the articles but it's not in open defined and/or specified paragraphs. The burn rates are byproducts of the experiments and is why there's nothing in stone.
21 - 29 of 29 Posts
