1 - 20 of 22 Posts
2008 Trailblazer SS
Like the title says, I'm looking for a front driveshaft (not sure if there are any differences between years but it's for a 2008). Let me know what you have. I'm looking to find one with a slightly different placement of the balancing weight than what mine has. Thanks.
2008 Trailblazer SS
Cool, can you check approximate shipping to 06457? Also, can you measure how far the balancing weight is from the end (end closest to tcase). Much appreciated.
Yeah, ill get a measurement for ya. Might be friday until i get shipping quote
2008 Trailblazer SS
No problem. It's not a huge rush. Thanks.
2008 Trailblazer SS
The position of the balancing weight is the more important part honestly. Shipping is shipping.
2008 Trailblazer SS
No problem. Anybody else?
I have one... I will check the weight (not 100% sure way it matters along as it's balanced).
2008 Trailblazer SS
Thanks. Let me know. I'm having a clearance issue based on the position of the current weight. A slightly different position would fix it.
On the diff side center of yoke to start of weight 4.5" back side of weight 5" weight is about 1/16" thick.
2008 Trailblazer SS
Discussion Starter #12
Thanks Bryan. This is the weight that I'm referring to. I'm hoping to find one moved slightly forward or back.
2008 Trailblazer SS
Discussion Starter #14
If you have no weight on the transfer case end that would be perfect. Thanks again. Not sure if it matters but what year is it off of? Are you officially rwd now?
2008 Trailblazer SS
Discussion Starter #17
If the other parts don't work out, I've got one too. I'll look for the weight location tonight.
Thanks. I have nothing locked in at the moment.
2008 Trailblazer SS
Discussion Starter #18
Can somebody verify if all years have the same front driveshaft? And if non SS models are also compatible...maybe somebody with dealer access. Tim? I still need one if anybody has one collecting dust and rust.
1949 TrailblazerSS
I have one from an 06, the weight on the transfer case side is about 9 1/4" to 9 3/4"
2008 Trailblazer SS
Discussion Starter #20
I'm having some other work done, but might still need this. Just so I know, which point did you measure from? I need to re-measure mine. Thanks.
1 - 20 of 22 Posts
