1 - 20 of 37 Posts
07 TrailblazerSS Imp
I know I havent been on here much lately but figured maybe I need to be with my growing business of after market parts. I sell:
LED bulbs everywhere they are replaceable plug n play, headlight, signals, reverse, interior, exterior, canbus, srck, switchback, colors
the oil pan baffle $25 shipped (stops the oil sloshing to the rear and pick up starvation) 1140 sold to date
Door sill plates $60-110 from acrylic with leds-still and motion, billet-powder coated and or polished
Bumper step plates $145-$245 (cnc machined raw up to powdered/polished/red led brake light) currently temporary suspension until more are machined. I do have ones with lines only and no SS in the middle.
Aluminum shroud efans 3 relay harness $300
Ported and polished throttle body $100 exchanged
Tribotex oil additive I am no longer selling due to a fallout with the CEO over my low prices. You can visit their site to purchase it.
I have teamed up with Richard Sheffield recently where we will be making carbon fiber parts soon (molds are being made as we speak)
] 7763C6B1-A694-4422-BE18-B700E266F494.jpeg 71F39AB4-FF73-4632-A834-83D4EC8F51A6.jpeg 8DFFFF18-6694-4ECE-A9B4-5CDAC15A3F96.jpeg AF9CD388-C5B5-4C16-8D92-AB8947826A4F.jpeg AAEAE0CD-7D28-4F89-B3EF-B60498292593.jpeg 20A2CD0C-D587-429A-9C5E-6A1E0BAB6E2D.jpeg
I am waiting to hear what carbon fiber parts you're going to offer!!
Sent from my SM-N950U using Tapatalk
Many parts - hood, wiper cowl, radiator cover, rear valance, dash bezel, door handle bezel, pillars, panels, fan shroud, console, etc. Its a major under taking at the moment to get molds made.
Lighter-than-you
I haven't seen many good pictures of the oil pan baffle mod to tell if it's used along with factory baffle or by itself. Also, does PCM's oil pickup tube work with your baffle? Is there a benefit to using both?
The oil relocation tube is a totally different adaptive fix to the oil sloshing. My baffle is a vertical wall attached to the stock splash tray, stopping the oil from sloshing away from the stock pickup tube. Its a simple drilling of 2 holes in the splash tray, popping two rivets to hold in place against the axle tube...right behind the stock pickup tube.
PCM relocate has you removing the stock splash tray-grinding 8 rivets to do so. Then you are required to drill 8 new holes to attach/screw their 2 splash trays back in, which directs oil back to the 6" longer pickup tube into a smaller area behind the axle tube.
F532CE3A-1F08-4718-9A50-3E2800486FB1.jpeg 6D6D5364-BC63-40AA-8FB3-1E07CBC958DA.jpeg
Kevin. Did you ever get more LED high beams in for the TBSS?
2008 TBSS Super Charged
07 tbss awd
Definitely excited to see these carbon pieces! I still need high and low beams but I never seem to get around to ordering them!
Discussion Starter #14
Richard has a guy now making molds to start producing parts. Its a long tedious process so its not going to be anything happening quickly.
Discussion Starter #16
Sure all are the same as the TBSS and I sell thousands to them. hi, lo and fogs are $120 for all 3
Kevin. Did you get any hi beams in yet?
No problem with the LED’s working in the stock headlight?
Reactions: SleeperSS
1 - 20 of 37 Posts
