1 - 18 of 18 Posts
2007 tbss 2wd
2007 tbss 2wd
kk thanks
325s wont fit?
2006 Red Jewel AWD
If you are looking for a rear wheel for a drag set-up, KMC will do their XD Monster wheel in an 18x9 in our bolt pattern, you just have to know who to talk to...they have blank wheels they can cut the lug holes in our pattern...
2007 tbss 2wd
yeah makes sense. i just cant get traction with the 275s i have now, but there alittle old maybe new ones would work better haha
2007 tbss 2wd
ok thanks man maybe ill call them tommrow
Administrator
how much do you want to spend a wheel. is 275 bucks a rim to much>?
2007 tbss 2wd
no thats not to much at all that would be great
2007 tbss 2wd
thought so i was hoping that was the case. do you have 17x11 rims? or 17 by 9.
what back spacing do i ask for or will they know?
2006 TBSS
I have 17x9.5 rears, because I wanted the stepped lip. The 325 M&Hs run small and fit fine on the 9.5" rim. I had my wheel specifications adjusted slightly. Here is the original thread with pics. If you decide to get the same specs you can reference the TBSS with the 17" drag pack on the True Forged Customer Gallery page.
http://www.tbssowners.com/forums/showthread.php?t=52034
Administrator
17x9.5 on the wheels i sent you.
9.5 with 6.5 bs and have him shave off the rear mounting pad get more lip on it.
Administrator
I have 17x9 rears, because I wanted the stepped lip. The 325 M&Hs run small and fit fine on the 9" rim. I had my wheel specifications adjusted slightly. Here is the original thread with pics. If you decide to get the same specs you can reference the TBSS with the 17" drag pack on the True Forged Customer Gallery page.
you wheels are 9.5. All true forged stepped are the wider 9.5 or 11. No such thing as 9 on those wheels unless you paid another 500 dollars to cut the hoops down (talked to steve before your wheels went in to get the backspacing done and know it was a 9.5.)
You guys will see my true forged set up soon
2007 tbss 2wd
Discussion Starter #15
2007 tbss 2wd
Discussion Starter #16
o ok sorry 17x9.5 with 6/127 bolt pattern and 6.5 back space got it sorry guys thanks
Administrator
no problem ive been telling people about those wheels for a while because I use those wheels on s10 trucks I do. For the price they are good just a little ruff finish thats all.
and yes like I said 17x9.5 with 6.5 bs and 6x5 bolt pattern. And last i talked to jeff there they can make the 5 star wheel in the 6 lug design so id call and just check again.
2006 TBSS
They are 9.5. Don't know what I was thinking :doh:
1 - 18 of 18 Posts
