1 - 9 of 9 Posts
Will this grill fit the SS? It's for a reg TB 09 I think. Or should I just get another SS grill?
I like the look of the Huricane grill from the SEMA show and wanted to mess around with an open grill look. I know I'll need new headlights too.
07 Imperial 1SS 2wd
Where did you get that grill at?
07 Imperial 1SS 2wd
So you just bought the middle grill and then cut the ends off your old grill snap onto your headlights?
Correct.
I cut out the headlight grilles, sanded them down on the corners that I cut, installed them first then the middle section of the grille was placed over them, then marked and sanded down to secure everything into place.
07 Imperial 1SS 2wd
I might try doing this setup, I would like to get another stock grill to use instead of hacking mine up.
Also could you post some closer shots of your grill with better lighting? Thanx
1 - 9 of 9 Posts
