1 - 8 of 8 Posts
When i was home on leave in texas i noticed a wierd noise coming from the left front. So i jacked it up and played/pulled/jiggled everythingi could and couldnt get any noise. Now fast forward im in florida and its gotten worse i canreally here it when i turn its like a ratting/metal squeaking noise.
Suggestions anyone??
08 Black Granite
Are you lowered?
Stock?
What components were used if lowered?
u sure its not ur brake pedal... everytime i go over bumps myine rattles
Sounds like your front hub is bad to me. I had the same thing happen to mine at 23k miles. Dealer warrantied it even with mine being lowered.
Did you check the dust shield? Don't know if that the correct term but its behind the rotor perhaps it rubs a bit need to bent out.
1 - 8 of 8 Posts
