1 - 9 of 9 Posts
· Registered
Installed belltech drop struts on my 09 awd. Did the single smaller spacer intending for a 31.5 drop but ended up at 30.5 instead. So... What's up with that? I can take them apart to add the extra spacer, but seems kinda odd that I ended up with a totally different ride height than I should have.
· Super Moderator
I have 1 small 1 large collar and I believe I'm at 31.5, 08 awd
Keeping an eye on this thread..I also have a 09 AWD and purchased the 31.5 kit..😳🤔
· Registered
2006 Black 3SS AWD
Do you have stock size tires? I only ask, because that can throw off the measurement. You might need to look at part numbers, may be incorrect springs.
Sent from my SM-N950U using Tapatalk
Sold
Stock size tires. I need to replace a rear ride height sensor because It broke so my rear bags are totally deflated, but I doubt that's going to make much difference.
I recommend getting the metal threaded rod replacements. I bought a set of them and they worked great. You could even make your own. Search this forum for more exact details.
· Registered
Graveyard bump. I ended up putting an extra 16mm spacer in and that fixed it. Then I got sick of my ride height sensors as.breaking and went 31.5 coils in the back. Once I did that, the front ended up higher than I expected. Probably gonna take a spacer out and see if it gives it a little rake, it's pretty much flat now.
Anyways, if your ride height up front seems wonky, it could be caused by the tears.
· Registered
So you have two 16mm spacers on each front strut and the 31.5 drop springs in the rear, and that has you level at 31” all the around?
· Registered
Discussion Starter · #9 ·
I'll have to check, but my front ended up a little higher. My front end.isntorn apart for a header install that's been way more of a pain than it should have been
1 - 9 of 9 Posts
