1 - 5 of 5 Posts
'07 3SS AWD
Hey all,
I have that famous ringing noise that increases with RPM coming from my driver side rear speaker. From what I can see it's most likely a grounding issue. I see the Bose wiring diagrams from this thread:
http://www.tbssowners.com/forums/tech-talk/22420-tbss-audio-wiring-info.html
But I'm just trying to kind of make sense of it.
Where should I be checking for loose grounds? I see some suggestions of under the center console. I haven't really messed with the audio wiring before.
For what it's worth, I have a 10" sub run off an amp. Otherwise I have the stock Bose nav head unit/speakers.
Any suggestions?
· Hooked on speed
06 Trailblazer SS
If you have rear seat audio controls the problem is in the console. I can bang my elbow on the back of the console and it stops. Took a while to find the problem.
'08 Silver TBSS
Check/clean the ground for your amp. I just had a ringing problem like yours and it was a bad ground.
· Registered
Hey all,
TBSS Audio Wiring Info
Any suggestions?
Did you ever fix the problem? If so, how did you do it. The links, above, no longer work and I am having this issue in my 2008 TBSS. Thanks.
1 - 5 of 5 Posts
