1 - 6 of 6 Posts
TrailBlazerSS
jw where everyone grounds there amps/batteries in the rear. I find that the seat bolts arent that great being that they are painted.
I used a factory ground that is next to each tail light, underneath the plastic panels, there is one on either side. Seems to be working fine...
TrailblazerSS 2008
I grounded mine on the lift gate latch, between it and the body. Will take a pic if you msg me about it. You can still see it, but not by much.
You can ground it anywhere there is a solid flat area. Make sure to clean the metal so you have the best grounding point possible. I removed the quarter trim and there is double wall steel back there that makes an awesome grounding point.
1 - 6 of 6 Posts
