1 - 12 of 12 Posts
I'm looking to change out my shocks for some new ones and figured instead of getting factory replacements is there something better I could be throwing in there? I know Tony sells the street performance belltech shocks but I was not sure if those were to use with the springs only ? I still have the factory airbag setup set at about 31 inchs. Thanks
Administrator
you can use the belltech street performance with the bags they ride better than the stock shocks. Many have done that here. jonlisaloser is one members truck I did you can pm him it rides better than the stock shocks.
Ok cool thanks guys. Obv no real trick to doing rear shocks, I asume it's a easy job.
Administrator
takes 2 minutes per side with impact
2008 Trailblazer SS
can you run those shocks with the springsy ou sell Tony? i know alot of guys have said the ride is great...and you get to lose the compressor
I have the double adjustables....i'd recommend them definately if your keeping bags. If you go springs you can get away with the street perf Tony mentioned....just my opinion though.
TBSS 3SS
DJM 1800 series shocks
its what I have on mine at the moment
How does it ride? I'm very interested in purchasing these shocks. How are you lowered - bags or springs?
Kinda deciding between
Belltech Sport Trucks 25011 - Belltech Sport Trucks Lift and Lowering Shocks
http://www.summitracing.com/parts/BEL-25011/
DJM Suspension 1800 - DJM Suspension Twin-Tube Shocks
http://www.summitracing.com/parts/DJM-1800/Application/?query=Year|2007|Make|CHEVROLET|Model|TRAILBLAZER&prefilter=1
Death Machine
DJM 4 inch lowering springs in the back as well.. It rides alright.. its nice and firm.. not back-breaking.. only thing I dont like about them is the finish that DJM uses.. starting to show surface rust after 3 years lowered
Administrator
and if you only want to do the rear
http://www.tbssowners.com/store/index.php?act=viewProd&productId=111
the rear belltech shock/spring kit rides very nice.
2006 TRAILBLAZER SS
Does that kit you posted tony eliminate the airbags/compressor setup?
Administrator
yes but if you want to cut the spring to go lower i spec out a different shock since the one for the kit i list is the uncut spring.
1 - 12 of 12 Posts
