1 - 9 of 9 Posts
I know this is a shot in the dark but I can't for the life of me figure this issue out. I've gotten under the vehicle and see no leaks or anything that would indicate an issue, no burnt looking wire harnesses etc. However anytime i get the car upwards of 60 (Giving it some gas) I can smell something burning off. Idk if its cats or what, I am stock and running 7qts of oil, AWD if that makes a difference. Any ideas guys? I can't say for sure how to describe the smell whether its an oil smell or sulfer, all I know is it stinks and I'm paranoid... Any suggested areas to look at would be helpful. Thanks!
With a cold engine you can usually feel for manifold leaks. While on jackstands you can check the rest of the exhaust system too. Again check from a cold start so you can put your hands on joints and not worry about getting burned.
but since its only at speed, im stumped. Youre not loosing any fluids or coolant?
06 Silver stone 3SS
Look for broken bolts on the exhaust manifolds, I hand the same issue when you accelerate aggressively you can smell the exhaust inside the truck, normal driving never smelled anything and also never heard a exhaust leak. Replace broken bolts, new gm gaskets, and headers. No more issue.
Check under the front wheel well and look to see if the rubber flap is flipped back and resting on your exhaust manifold. Happened to me and drove me nuts until I found what the burning smell was coming from.
Sold
You said sulfur smell and that leads me to catalytic converters
1 - 9 of 9 Posts
