1 - 20 of 28 Posts
2007 TBSS 3SS
Changed out the front door handle for a rear one with no key hole.
Plasti Dipped the wheels and brake vents
Took off "Trailblazer" from the back hatch and the GM chiclets.
Looks good
I did the door handle mod on my old sierra, it was awesome till the battery died and I had to break into it to pop the hood to jump it.
2007 TBSS 3SS
Thanks
I should say I had alot of help from my 5 year old and my dad. Im kind of limited because of my back. Just wanted to knock out some of these things before i go into surgery on wednesday.
Oh yeah i also cleaned up the engine bay and cut the engine cover to fit my CAI.
2007 TBSS 3SS
Yeah had it on my 09 silverado. I went to North Dakota, Wyoming, Montana and Colorado for work for a little over 2 months and when i came back of course the wife did not turn the truck on at least once a week like i asked her to. Anyway i managed to take the bolts off of the hood latch. LOL
Looks good. Pull the bowtie on the lift gate and it will look even better
Looks good.
Good luck with your surgery wednesday.
2007 TBSS 3SS
Discussion Starter · #11 ·
=ЯΛWSSUM=
Any tips on the fans and harness install.. going to try and do this hopefully this month..
Yes... I know I'm short
'07 TBSS 2WD
That would be my concern...
2007 TBSS 3SS
Discussion Starter · #18 ·
I tried to knock the fan clutch off with the belt on but there is just not enough room with the hood rod. I gave up on that and used a c-clamp on the water pump pulley, also put some WD40 on there. You will have to take off the top rad hose to take the stock fan out, i tried with it on but after a while of trying just put a pan under the truck and took the hose off. Came right out.
The instructions are pretty detailed. You should not have a problem.
1 - 20 of 28 Posts
