1 - 6 of 6 Posts
Guys getting a set of trickflows. For those of u running these got a couple questions.
Stock GM head gaskets?
Arp studs or head bolts?
Stock rockers?
Push rod length, best out there?
Who's cam is everyone running.
Thanks for your help
Stock rockers?
GM gaskets
I used STUDS, but ARP bolts will make life easier if you ever need to pull the head
rockers-already answered
PR length-depends on lots of variables. measure for the right length, but 7.35 should be close to get you started
Cam-depends on your goals....
08 TBSS
I'm running the Trick Flow 225's, and LOVE them.. Seems like the other gentlemen have covered your questions.. I am on cam number 2 with these heads, and both cams work well based on the goals at the time of the cam swap..
Perfect. Thanks for all the input.
Which rocker is better?
For the guys running stock rockers with Trickflows ( couple on the fourm) what do you have to do to the Rocker guide tray?
1 - 6 of 6 Posts
