1 - 14 of 14 Posts
Notorious
Well after that pathetic and absolutely disgusting 14.9 @ 92, I decided to give another go at it. The track was closing in 30 min and I had the wife and kid with so we decided to shoot down there after our haunted hayride. The CEL was off and I pulled the #61 fuse. DA was 760, it was 600 when I went 14.9.
Here's the new time, 100% stock AFAIK 2007 AWD 3SS full weight....I footbraked it as high as I could.
2.09 - 60ft
9.06 - 1/8 ET
78.7 - 1/8 MPH
14.07 - 1/4 ET
97.6 - 1/4 MPH
I was so relieved. I can breathe easier now....
My hope is for MAYBE a 13.999 later this month. See if I can do it stock.
07 TrailblazerSS Imp
Thats a good 60' time for being stock and the 1/8th is also pretty good. Where you are losing it is in the last half.
Notorious
Maybe RWD? I'm AWD. This was also after driving 20 minutes on the highway and pulling straight to the beams. It helps when your buddy owns a dragstrip :D
I then hotlapped and ran 14.3 @ 96.9 but I jacked up the launch bad and tapped the brakes.
Notorious
Ya I figure I should be getting maybe 20mph gain on the big end. However it is a heavy truck.
do you mean your trap speed should be close to 117? by saying gaining 20mph on the top end?
if so, no way not even close
Notorious
Discussion Starter · #11 ·
I pulled my air filter, bought the truck 3 weeks ago and never looked at it. It looks like someone dumped a gallon of dirt into it. Replaced it immediately.
'08 SRX V-6 AWD
Drop your spare, run with the gas at 1/4 tank, pump your tires to at least forty psi and you'll be below 14 seconds and 100 mph+ when the DA is below 500.
This is assuming you can duplicate your 60 foot time.
I ran 13.6 @ 101 at Norwalk last night when the DA was around 800.
Garage Queen
hey Paul... are the test n tunes still packed up there... im trying to make it up there one last time... to see what the numbers are like in some cooler weather...
1 - 14 of 14 Posts
