1 - 13 of 13 Posts
so lately when driving my 07 awd ss there has been a weird noise coming from the front...its hard to explain what type of noise. It almost sounds like a slight rubbing...almost like a train on deceleraton (but not as loud)...but the noise gets loud when doing 40mph and coasting. It also gets more noticiable on gradual turns at speeds of 30-40mph. At times I can feel slight vibrations in the steering wheel and they go away just as fast as they appeared. I still have some waranty left on it. I just had the trans flushed and installed a brake duct trans cooler. All the fluids are at the correct level. Has anyone else experienced this or know where to start looking at?
TBSS Black 2006
They would need to be replaced. I believe this is covered under your warranty. Otherwise it's around 133-150$ for the good bearing or take your chances with the 50$ eBay hub/bearing assembles.
07 TBSS
If ur not sure if its noise is from the drivetrain or the wheel bearing, what I like to do is drive at the speed that's its making the noise and if u can with no cars around you put it in natural and shut it off... If the noise goes away u know its in the drivetrain, if it stays then u know its in else where.. just my :2cents: BTW just make sure u don't lock the steering wheel lol u shouldn't be able to anyways..
I'm in des plaines....I'll probably be making an appointment up by you soon Greg....tried what XMONTE suggested and the noise is still there when the car is off and in N.
1 - 13 of 13 Posts
