1 - 20 of 58 Posts
Looking for pictures of AWD lowered by replacing the front struts only (and rear bag adjust of course). I want to lower mine but I don't want to shell out the money for Tony's a-arms right now. Want to see if its worth it or not...
Also, we can go as low as 31.5" in the front without having any issues, correct?
white 3SS
Im awd and have beltechs in the front with tonys a arms. Im at 30in iv changed the wheelbearings once but have had no problems yet. Iv been this low for 2.5year now.
larrballs tapatalk
2007 3SS AWD
bump, subscribed ...
with drop struts 8mm spacer you will be at 31 with the 16mm spacer 32.
2007 3SS AWD
:iamwithstupid: looks mad good
white 3SS
I have a 8mm spacer on each side and im at 30in in front..im at 29 3/4 in rear with beltech rear shocks (witch make a way better difference) if i could do it again i would go with kbee's for the front for a better ride. Other then that i love the way it looks n rides. Next are black 22s:yay2:
That looks like a nice Christmas card
Larrys sits about like mine....Im on Struts and Bag adjustments, but I do have A Arms though.
white 3SS
@matt....you useing spacers in the front?? And if u hit a good size bump or hole does ur a arms hit the spindle deal where the balljoints at?? Mine does n sometimes hits hard
save money for your aleing transmission!!
@whitetbss
I'm using a single 8mm on the passenger side, and I don't hit at all because I ground some serious clearance points in my A-arms prior to
having them powdercoated and installed.
Check the top of your wheel well for marks from the a-arms hitting. That's where mine are hitting on big bumps, I know people who cut a section out and it doesn't hit anymore.
Discussion Starter · #18 ·
I appreciate the pics/responses but as I said i'm looking for pictures with lowering struts ONLY....
A Arms dont change what your looking for as they dont do anything for a lower drop in Pictures. What has been posted is EXACTLY what you asked for whether you realize it or not.
Discussion Starter · #20 ·
Usually people with a arms are lowered more than without a arms.
1 - 20 of 58 Posts
