1 - 3 of 3 Posts
TBSS 3SS
I installed corvette servos this weekend and took it out for a drive but may have a problem. It feels like it doesn't shift into 4th gear. Double check the install today and its correct....damn Pain-in-the-ass to take the cover off.
At 60mph my RPM is 2500-2700 and as I shift the level from D to 3 there is no downshift.
I read somewhere if you installs aftermarket servos, to change the transmission line pressure back to stock.
Here are my mods:
1. Stock Transmission
2. Corvette Servos
3. BBA 8-05-2010 tune.
What is the easy way to do this?
Thanks in advance for everyone's help.
2007 AWD 3SS
You messed up the install. If it doesn't shift to 4th, it's not a line pressure problem, in fact it should shift harder into 4th if you replaced the 4th servo.
Two things:
1. Servo installed wrong...
2. Pin length is too short. (since you have 2nd, I would doubt this).
Put the stock servo back in or take it to a trans tech who knows what he's looking at.
TBSS 3SS
Thanks for the insight. I will open'r up again to double check my install. I'm confident you are right.
I can't complain enough how much of a bitch is to take off the cover. :doh: Its definitely a two person job.
I appreciate your quick help and your awesome tune.
1 - 3 of 3 Posts
