1 - 1 of 1 Posts
I’m in the process of doing a frame swap on a 06 TBSS and after installing the motor, transmission and transfer case as one piece the transmission will not engage in park. The linkage shifts through everything as it should but when it’s in park the chassis still rolls. The front driveline is not installed but the front output shaft is rotating as it should so I don’t think it’s in the transfer case. Any ideas?
1 - 1 of 1 Posts
