1 - 7 of 7 Posts
Have to do a transmission fluid and filter change on my TBSS AWD. I’m going to Change the pan also. My question is.
I want to add the items below. Do I have to drop the transmission?
  • Sonnax HP-4L60E-01 kit
  • Sonnax 2nd servo 2nd Gear "Corvette" Ratio Servo Kit Part No. 77701-04K
  • Sonnax Super 4th servo 4th Gear Super Hold Dual Servo Kit Part No. 77767K
Can the servos be added without dropping transmission?
PFA:
Justdid this last weekend, new filter and fluid. Added sonnax pinless accumulator 77998-03k, pinless forward accumulator and new gm corvette servo. Was not hard at all, can be done in 1 night and only have to drop pan and filter. 1-2 shift is firmer, rpm drops less and 3-4 shift is sharp, dropping some pedal in 3rd also feels stronger, best bang for the buck.
Civteck so for the parts you added you did not have to drop whole tranny out truck?
what part numbers did you use for:
  • pinless forward accumulator?
  • new gm corvette servo?
Thank you for all your help/info.
Reason asking these questions is since I have to do tranny fluid and filter change what can I update in tranny since opened up there but without having to drop tranny out.
Correct did not drop the trans. Being awd also i did not want the sonnax servo thinking it would be too much for my geriatric trans to handle, and i didnt want to reuse my old parts as that kit does. These are the 2 kits i bought and installed. The sonnax kit will only use 2 of the 3 parts as i believe the extra is for the 700r4
101584
101585
101586
101587
Reactions: Mitch808
What brand and type of transmission fluid did you do go with? I have a 4L70e filling it for the 1st time.
OEM General
1 - 7 of 7 Posts
