Ok so today I installed my new torque converter and pump, everything went good. Test drove it twice then checked the fluid all good go to leave and the truck won't shift into second when it finally does decide to shift into second it shifts hard as hell. Then I got the code po700. Can't run trans codes until Monday. Any ideas what would cause this? Also what solenoid is the one that goes directly into the side of the pump that's right under the tcc solenoid. It's the one that has the two bolts holding it in and has the copper wound around it the has a shaft with a o ring on the bottom part of it that goes into the side of the pump. I'm thinks it's deff some sort of electrical issue.
