1 - 11 of 11 Posts
Just put on the duct mount trans cooler and wondering if the lines need teflon tape as well cause they are leaking
sent from my HTC Thunderbolt
2007 TBSS 3SS
Is it the PCM4LESS kit?
The AN fittings don't need Teflon tape. They may not be tight enough. Take them apart again and check the threads, maybe some debris?
- Sent from my iPhone using Tapatalk
Yep they weren't tight enuf, no leaks
Yeah it looks like the its supposed to in the picture
Just curious, on the cooler itself - did the fittings thread all the way down for you?
The fittings on the cooler didn't but I got them as far in as I could
'07 3SS AWD
Make sure you do not overtighten the AN fittings, you can damage the tapered seat and it will never seal tightly.
The cooler takes NPT fittings (National Pipe Thread) they are tapered so you will still see threads when it is tight.
Discussion Starter · #10 ·
Elbow is on the top next to the frame and the straight fitting is on the bottom
1 - 11 of 11 Posts
