Thank you for the photos Scott, helps out a bunch to show what you did.40k trans cooler fits in front of the radiator with only minor trimming of the black core and a slight bend in the center hood support.
AWD or RWD? What size stall? I'm doing a stall and other work this fall and have the brake duct kit now and need to know if I need to plan bigger.I was using a larger radiator inline with a PCMofNC brake duct cooler (no fan). It isn't enough for a stalled trans..working my 40k install currently.
you can one and done it with a trucool 40k. But you could also run a secondary cooler in your other duct.AWD or RWD? What size stall? I'm doing a stall and other work this fall and have the brake duct kit now and need to know if I need to plan bigger.
Doing a stall and internal mods this fall so looks like I'll have a brake duct cooler for sale soon.you can one and done it with a trucool 40k. But you could also run a secondary cooler in your other duct.
Just make sure you use quality lines as dual coolers introduces more points of failure. A nice AN setup with braided line that support at least 250deg or more. Most rubber lines are in the 220 range or so and you have to look far and wide for higher rated temp lines
Not try to start anything here, but you can't use ports pointed down. It's only filling up maybe a quarter of the capacity, not effectively exchanging heat.. I'd bet a million dollars that trans will run cooler with ports pointed up.. This seems to be a very big mistake that a lot of tbss owners are making.40k trans cooler fits in front of the radiator with only minor trimming of the black core and a slight bend in the center hood support.![]()
This is not true.Not try to start anything here, but you can't use ports pointed down. It's only filling up maybe a quarter of the capacity, not effectively exchanging heat.. I'd bet a million dollars that trans will run cooler with ports pointed up.. This seems to be a very big mistake that a lot of tbss owners are making.
Again, just trying to provide correct info for the community![]()
Go look at any late model GM truck in your apartment complex. Trans cooler fittings are on the bottom.#Iamnotwrong Go ask any professional race team how they orient ports on coolers... Moreover show me one example of an OE cooler with ports on the bottom. The hose itself is the least restriction, the cooler is the most restricted. I stand firm that the cooler will not fill up all the way with ports on the bottom... It's called gravity!
Now go do some more research and you will once again find out that you spoke before checking your facts.
My '04 DMAX has the ports on the bottom as pictured above. I swapped it to a larger unit in the OE position though. I would commonly tow pretty heavy, my trans is heavily built with a 3 disk billet convertor. It also makes about 600hp to the wheel, and I live in Phoenix. Cooling systems need all the help they can get.Here's more food for thought... My 07 Dmax has its factory trans cooler's ports mounted up. Wouldn't you want to use the same orientation used for cooling an Allison that's rated to pull over 20,000lbs uphill?
