1 - 10 of 10 Posts
My tbss tranny wont go over 20mph. Unless i shift it to manualy to second keep in mind i had it rebuild about 3months ago what causes it to mess up
Any info would appreciate it
Moderator
I hope he didn't cost you too much.
Did u have the converter cleaned out?
Moderator
If the trans took a dump and u had it re built. More then likely parts of the trans got into the converter.
Might have to take it back to them and have them flush converter AND lines, and put new filter. Will most likely have to clean out valve body as well. Your be lucky if thats all it is.....
Moderator
Let's hope because. $1,000 is super cheap for a complete trans rebuild.
Well i got the tranny fixed but now a check engine light is on didnt have on before
Scanned it code P0330 came out
'08 TrailblazerSS
Knock sensor circuit bank 2.
Check the wiring for the passenger side knock sensor and make sure it didn't get damaged when the trans was pulled and reinstalled.
1 - 10 of 10 Posts
