I don’t know if I’m fortunate or unfortunate since I was able to get a set of Tony’s redesigned upper arms (id ask him but he’s a ghost) before he dropped off the planet. So the issue I’m having is the steering feels loose at times especially going over bumps. I grabbed the upper part of the tire (with it on the ground) and put inward/outward pressure and I could see the ball joint moving, I was also getting a popping /clunking noise. I replaced new ball joints thinking that was the issue, regreased everything. It still appears that there’s movement between the arm and the ball joint. My question for anyone that was able to get the new arms have you had similar issues and did anyone have to modify the arms like the 1st gen by enlarging pinch bolt hole adding a 7/16” bolt??
