Throttle body cleaning=high reving idle?
9.7K views 24 replies 13 participants last post by  Jvoisel
#1 ·
cleaned the throttle body yesterday now I have a high revving idle. Is this common after you clean a throttle body? 2007 tbss
#3 ·
:iamwithstupid:
#5 ·
Its gonna take a while to relearn the airflow. I cleaned mine 3 weeks ago and I'm still having issues at idle. Wish I would've just left it alone. I might just have to buy a new TB though because when I cleaned mine I held the blade fully open to clean the crud out good and from my research they say to touch the blade as little as possible becaue of the servo motor inside. Whoops.
#8 ·
Im interested in hearing the answer for this because as a Nissan tech we always clean electronic throttle bodies and same thing happens, idle is now higher or erratic obviously due to no IAC valve anymore and the PCM uses the blade opening angle to control idle speed airflow.
Anyway for Nissan every time we clean the throttleblade, we then hook up our scan tool and perform whats called Idle Air Volume Learn and it reset the idle back. Does GM have a similar procedure?
#10 ·
GM does have a idle relearn procedure but it has mixed results on actually fixing the idle. For most people it doesnt actually do anything. From my research it looks like the idle relearn isnt supposed to actually fix the ghigh idel, it just resets the learned idle airflow to speed up the new learning process.
And I tried disconnecting the battery as well and that did not change anything. I even disconnected the battery before I pulled the TB and cleaned it. But it had never been touched in 88,000 miles so it was pretty gunked up. I'm wondering if that is why it is taking so long to relearn. Or I just messed up the servo motor from holding the blade wide open?:doh:
#16 ·
I have had many instances where idle relearn or driving for weeks wont do a thing for it. If this is the case you will HAVE to reprogram the ecm.
#19 ·
I took my TB off 2x to clean and after reinstalling it and it started up and idled like normal. :dunno:
#21 ·
turn the key on and put something on the pedal to hold the throttle open, just dont bump it to the start position. thats how i do it. This way you arent forcing the blade open.
#23 ·
Its runnIng perfect today. I installed a new throttle body and reflashed the pcm yesterday and had no luck. After the cool of from yesterday its back to normal. Gm said my tps was bad and that they can go bad from a gunked up throttle body. They said just clean it once a year by spraying throttle body cleaner on a shop rag and wipe it clean with it still attached and be gentle on the blade.
