1 - 20 of 32 Posts
Can you say 9's
AWD Trailblazer SS
On 8lbs 500/525
Max boost finally came on around 5k rpm... Maybe around 5200.
Sold
This is Chase's old TBSS correct? So you are 100hp down from the 1900 setup? What am I missing here....
Your not missing anything... That's what I'm little irritated about. Trying to get the bugs worked out on why it takes so long to spool...and that's also on 4lbs less of boost
Nope t6 1.32 ar
Just a noob
How many lbs of boooost are u planning on? I'm sure you will get it figured out because 8 pounds at 5k isn't going to be that quick. Go do some wrenching and twist that wick!!
Got a few things I'm going to try first. And I'll be around 15psi once I get the meth back on.
making friends daily
07 TrailblazerSS AWD
It must be the color you picked for under the hood. Shoulda picked that other color lol. You'll get it dialed in. Checked for a leak somewhere. If its losing pressure somewhere it'll take a lot longer to make full boost o would imagine.
Reactions: J Rock
8lb spring?
Discussion Starter #15
It's on a 11psi now. Just wastegate spring
Moderator
This truck may have lost some power. But it will be capable of making serious power. Like he said he will work the bugs out. Plus the 4L80 is a loss of power.
Making 8 on a 11?
Discussion Starter #18
No was making 7-8psi on what was said to be 10lb spring. Then I added another on to it.. Which is supposed to be about 13lb together. But makes 11psi
Did you change the cam?
I bet once you start making more boost you'll be on par. You're probably not where you need to be on the turbo map yet
Reactions: J Rock
1 - 20 of 32 Posts
