Here ya go, hopefully this makes sense; I know I lose all of the formatting and nice pics when I paste.
Body Control Module (BCM) C1
Connector Part Information
OEM: 12110088
Service: 15306210
Description: 24-Way F Micro-Pack 100 Series (GY)
Terminal Part Information
Pins: A2, A3, A4, A5, A6, A12, B1, B2, B3, B4, B5, B6, B7, B8, B9, B10, B11, B12
Terminal/Tray: 12146447/3
Core/Insulation Crimp: E/C
Release Tool/Test Probe: 12031876-1/J-35616-6 (BN)
Body Control Module (BCM) C1 Pin
Wire Color
Circuit No.
Function
A1
Not Used
A2
WH
2282
Headlamp Washer Relay Control (CE4)
A3
OG
1140
Battery Positive Voltage
A4
BK/WH
1969
Headlamp High Beam Relay Control
A5
PK/WH
1970
Headlamp Low Beam Relay Control
A6
PK
5363
Inclination Sensor Low Reference (BAE)
A7-A11
Not Used
A12
WH
278
Ambient Light Sensor Signal
B1
L-GN
1037
Class 2 Serial Data
B2
BK
279
Ambient Light Sensor Low Reference
B3
L-GN
2270
Rear Window Washer Relay Control
B4
GY/BK
2226
Instrument Panel Lamps Dimmer Switch Low Reference
B5
GY
705
5-Volt Reference
B6
WH
2283
12-Volt Reference
B7
OG/BK
2090
Courtesy Lamps Supply Voltage
B8
L-GN
1011
Remote Radio Control Signal (STW)
B9
GY
391
Rear Window Wiper Switch Signal
B10
YE
1836
Security System Sensor Signal
B11
GY
2521
Right Sunload Sensor Signal (CJ2)
B12
L-BU/BK
2519
Left Sunload Sensor Signal (CJ2)
Body Control Module (BCM) C2
OEM: 12110112
Service: 12110112
Description: 32-Way F Micro-Pack 100 Series (TN)
Pins: E3, E4, E5, E6, E7, E8, E9, E11, E12, E14, F3, F4, F5, F6, F7, F8, F9, F10, F11, F13
Body Control Module (BCM) C2 Pin
Wire Color
Circuit No.
Function
E1-E2
Not Used
E3
L-GN
80
Key In Ignition Switch Signal
E4
YE
307
Headlamp Switch Flash to Pass Signal
E5
GY/BK
308
Park Lamp Switch On Signal
E6
PK/BK
109
Hood Ajar Switch Signal (UA2)
E7
PK
1348
Headlamp On Indicator Control
E8
BK
1835
Security System Sensor Low Reference
E9
RD/WH
812
12-Volt Reference
E10
Not Used
E11
D-GN/WH
1317
Fog Lamp Relay and Indicator Control (T96)
E12
BK
28
Horn Relay Control
E13
Not Used
E14
TN
5463
Daytime Running Lamp Override Indicator
E15-E16
Not Used
F1-F2
Not Used
F3
D-GN
113
Windshield Wiper Switch Signal 2
F4
D-BU/WH
1495
Courtesy Lamps On Signal
F5
BN/WH
1871
Headlamp Washer Switch Signal (CE4)
F6
OG
192
Front Fog Lamps Switch Signal (T96)
F7
L-BU
187
Rear Fog Lamps Switch Signal (T79)
F8
L-GN
5462
DRL Defeat Switch Signal
F9
WH
103
Headlamp Switch Headlamps On Signal
F10
L-GN
11
Headlamp High Beam Supply Voltage
F11
PU
328
Interior Lamp Defeat Switch Signal
F12
Not Used
F13
PK
5068
Intrusion Sensor Switch Disable Signal (BAE)
F14-F16
Not Used
Body Control Module (BCM) C3
OEM: 15354796
Service: See Catalog
Description: 40-Way F Printed Circuit Flexible (GY)
Pins: A1, A2, A3, A4, A5, A6, A8, A11, A12, A13, A14, A15, A16, A18, A19, A20, B1, B2, B3, B4, B5, B6, B7, B8, B9, B11, B12, B13, B14, B15, B17, B18, B19, B20
Terminal/Tray: See Terminal Repair Kit
Core/Insulation Crimp: See Terminal Repair Kit
Release Tool/Test Probe: See Terminal Repair Kit
Body Control Module (BCM) C3 Pin
Wire Color
Circuit No.
Function
A1
2140
A2
2140
A3
748
Right Rear Door Ajar Switch Signal
A4
1134
Park Brake Switch Signal
A5
195
Door Lock Control
A6
2265
Power Window Lockout Left Rear Control
A7
Not Used
A8
747
Left Rear Door Ajar Switch Signal
A9- A10
Not Used
A11
1350
Ground
A12
1353
RAP Supply Voltage
A13
194
Door Unlock Control
A14
1080
Park Lamp Relay Control
A15
5168
Power Sounder Enable Signal (BAE)
A16
5204
Intrusion Sensor Data Signal (BAE)
A17
Not Used
A18
992
Ignition 0 Voltage
A19
39
Ignition 1 Voltage
A20
541
Ignition 3 Voltage
B1
230
Instrument Panel Lamps Dimming Control
B2
230
B3
690
Courtesy Lamp Supply Voltage
B4
2240
B5
1186
Power Window Switch Right Rear Up Signal
B6
2266
Power Window Lockout Right Rear Control
B7
1188
Power Window Switch Right Rear Down Signal
B8
1185
Power Window Switch Left Rear Up Signal
B9
1187
Power Window Switch Left Rear Down Signal
B10
Not Used
B11
1350
Ground
B12
24
Backup Lamp Supply Voltage
B13
4440
B14
1382
LED Dimming Signal
B15
543
Accessory Voltage
B16
Not Used
B17
4040
B18
1732
B19
1977
Rear Fog Lamp Relay and Indicator Control
B20
5362
Incline Sensor Signal (BAE)
