1 - 20 of 20 Posts
07 TBSS imperialblue
Discussion Starter #2
07 TrailblazerSS Imp
mike, I just picked up a momentary switch at Home Depot for $5 and change........... and have these switches for my trans cooler efan and one other for future function. They have the blue light in them. I do have extras of these.
This is the momentary switch
These will need a standard on/off switch like you found at jegs
bottle opener sw, heater sw, a electric cut out sw
This will need a monetary switch as mentioned above
purg sw
thanks everyone for the help....
yea i am making my own panel going to put all the sw inside the console kind of like rich has and then put the purg threw the center of the console.... kind of like what kevin has
but going to try and use blue lighted sw to match my ride!!
Discussion Starter #12
damn now that is tight >>>>>>best one i have seen yet
Discussion Starter #13
what does each one do????
TrailBlazer SS AWD
Red Covered Switch = Master Arm
Yellow = DynoTime Bottle Warmer
Green = ZEX Window Switch
Blue = ZEX Nitrous Controller
Green = ZEX Bottle Opener
Red Button = N2O Purge
Discussion Starter #15
dude i have to give you props again that set up is sweet as hell...... but do u have to have a window sw???? i thought it would just stay on?????
TrailBlazer SS AWD
When The "Window Switch" Is On (Green Light On) The ZEX Window Controller Is Functional. Whe The "Window Switch" Is Off (Green Light Off) The System Will Run Full Time At WOT. No RPM Range, No Skipping Over Gears, Foot To The Floor, N2O Spraying Through The Full RPM Sweep & Throught The Gears.
Discussion Starter #17
so let me get this straight when the green light is off the nos still works but it might blow up all your shit... but when green light is on the window switch is armed so it saves your shit from blowing up.....well does better to protect it then when the light is off??? is that right???
again you set up with the sw are sweet!!!! if i didnt want to hide mine i would have to jump on that idea you got
TrailBlazer SS AWD
Green Light On Is Safer. But If A Street Race Pops Up I May Want Full Sray Off The Line At WOT, Not Just From 3000 RPM To 6000 RPM. Hopefully Nothing Blows Up. I'll Be Spraying For The First Time At ATCO This Oct 30th. So All Switches On Means I'm All Ready To Go. Plus It's So Much Cooler To Hit The Master Arm And Then All Of The Little Ones One At A Time.
Discussion Starter #19
hhaahhahah i got ya man..... like nascar ....shit is going to be sweet for sure
1 - 20 of 20 Posts
