Well, to make a long story not so long I'll skim through the "best" parts....
Back in January I slapped on an alky control setup as well as a ported intake and upped the boost from 7 to 9lbs on my frankensteined STS kit for just a lil more oomph. While at the dyno we couldn't get the boost over 6lbs... weird...
Not only that but while on the dyno we saw what looked like valve float... great.
To remedy the possible valve float situation I ordered up some ls7 lifters, ls6 springs and an ls2 cam among other bits and pieces so I could remove the weak link in my truck... the DOD system (did I mention mines a 5.3l lh6?)
A month or so later I was back on the dyno with a MBC thinking the boost problem was perhaps a faulty spring.... NOPE! After twiddling with it for a while and basically setting the boost to kill we still couldn't push it over 6 lbs.
Tuner thought that I might have clogged up the cats and couldn't get enough exhaust pressure to spin the turbo.... so I took it home and gutted the cats.... they were clean as could be.
Next up was the ported intake. Didn't see anything wrong with it on the truck but I was out of ideas and swapped it back out to the stock one and lo and behold I find I had cracked the seam on the drivers side on the manifold from end to end. lol.
Took it out for a spin with the stock intake back on and it ran much better. Although it had a clicking sound under throttle that I thought was perhaps an exhaust leak... I had just pulled the y-pipe so it made sense.
Got the ported intake fixed up and today (7 months later) I set about swapping it back in. While switching things over I noticed that a small piece of metal had taken a nick out of the butterfly on the throttle body.
After buttoning things up and fearing the worst I pulled the turbo.......
What. The. Fuck.
What. The. Fuck.
