After much research (phone calls, emails, texts, PMs, and measuring) and deliberation (aka. indecisiveness) here is what I settled on:
Note: I will be getting the rear shocks for about $56 each through a price match; and everything listed is either OEM replacement or a mild upgrade.
It is important to note that the ACDelco/Bilstein 540-481 struts are a 46mm mono-tube body (from this article:
Chevy Trailblazer SS - Super SUV Road Test - Super Chevy Magazine) just like the HD shocks; only their extended length is 16.61" and collapsed they are 11.41" (the only info ACDelco could offer), therefore the stroke is 5.2" and it is designed to work with the OEM 25mm lowering springs.
I went with the 4600 series HD shocks in the rear (the OEMs have a 36mm body) because my rear ride height (18.5" eye-to-eye) is pretty much dead centre in their 8" stoke (22.86+14.86=18.86"). It is clearly marked in the rub marks on the grime on the factory shocks, that my rear suspension travel is ~4" on compression. We will be sticking with the air bags for now, but if the they fail we'll look at springs or Gen 2 bags (
Gen 2 Air Bags).
There ya go. Want stock ride height? Buy stock parts.
Another huge issue for me was mono-tube vs. twin-tube:
Monotube vs. Twin-Tube - Fastline Performance Enterprise
You can see where the added stroke in the Belltechs comes from:
Mono-tube is superior in this application, IMO.
[quote="ACDELCO 45H0382 (19261985) Front Springs]
Spring Material Steel
Wire Diameter 0.670 in
Wire Diameter 17.02 MM
Spring Color Black
Grade Type Premium
Load Rate Front 1755 LB
Load Rate Front 796 KG
Spring Rate Front Constant
Front Spring Seat Included No
Front Spring Inside Diameter 3.7 in
Front Spring Inside Diameter 94 mm
Front Spring Relaxed Length 15.2 IN
Front Spring Relaxed Length 386.1 MM
Front Spring Compressed Length 10.5 in
Front Spring Compressed Length 266.7 MM
