So our trusty TBSS has turned 195,000kms (about 122K miles) and I would say that it is due for some new shocks, springs and a few other tidbits by the time it hits 200,000kms around Spring. It already has new MOOG ball joints, end links (F&R) outer tie rods, and TIMKEN wheel hubs.
A few considerations:
1. Must maintain stock ride height because we have 32" tall tires;
2. Improved motion control (dampening/rate to handle the heavier tires) without totally fucking up the ride quality; and
3. Fit a reasonable budget (ie. no coil-overs).
Here are most of the parts I have found that would be worth replacement and their various options (in no particular order):
Front
Shocks
ACDelco (OEM Bilstein) 540-481
Bilstein B6 (HD) 24-103336
Belltech F&R (combo) from the TBSS store
Swaybar Bushings (34mm)
Hotchkis 21810114
Prothane 7-1187-BL
Control Arm Bushings
Prothane 7-242-BL
Rear
Shocks
Monroe 58644 "coil over style" http://www.tbssowners.com/forums/showthread.php?t=94987
Bilstein B6(HD) 24-103343 (air suspension)
Bilstein B6(HD) 24-103350 (coil suspension)
Swaybar
Addco 29mm http://www.summitracing.com/oh/parts/aco-2211
Belltech 29mm 5530 http://www.summitracing.com/oh/parts/bel-5530
Hotchkis 27mm 2272 http://www.summitracing.com/oh/parts/hss-2272
DJM 27mm from the TBSS store
I cannot find the proper stock replacement front or rear springs (other than air); or the rates/data on much of the aftermarket parts offered. Can someone convince me of the legitimate benefits of going aftermarket?
Front
Shocks
Hotchkis 21810114
Prothane 7-1187-BL
Prothane 7-242-BL
Rear
Shocks
Swaybar
