1 - 20 of 23 Posts
So I have been contemplating this for a while, so I will pose the question since Ive never seen it brought up.
Can we Mate a Regular TB 4x4 Electronic Transfer case to the 4l70E Tranny?
If so, will it take the power?
I am sure the wiring to get it to engage, even if all homemade shouldnt be too complicated.
I have a couple of reasons for wanting to do this, and no Burnouts are not one of them....But would be a fun byproduct.
Discuss.
:king1:
stupid white guy
I'm interested in this as well. I think the only things that will matter is the bolt pattern from trans to transfer case and DS yoke and length.
Hmmmm.......a burnout switch?
I've brought this up before as well. It would also be something nice to have in the northern climates and still provide some slip in the wheels to ease the shock on the transmission.
:iamwithstupid:I would also consider it.
'06 AWD
Matt although this sounds great I say nay...the tcase could not possibly hold the HP you are gonna be making. Maybe stock HP but over time it too would greneade. The shock on it would be tremendous from a stand still and drag radials.
Fork/bearing failure is common due to the fact it is a heavy truck...now shock it with all kinds of torque and imo boom!
http://forums.trailvoy.com/showthread.php?t=47545
http://www.offroadtb.com/articles/tech-docs/transfer-case-tech-the-nvg-226-np8-theory-of-operation
Yea someone has brought this up before and the conclusion was pretty much the same, that the power would be just too much for it, but CAN THEY BE BUILT TO TAKE THE POWER?
'06 AWD
Last time I checked no..no billet front diff shafts or tcase internals. I talked with several of people I know in the offroad fab arena nada zilch zippo. I guess if the demand was greater maybe someone would undertake the venture. But it would be costly and I mean $$$$$. Nobody does the things guys here do to their vehicles not to mention we are the white elephant of the race community.
I think using the truck t-case from a 1500 frame GM truck would work. Lots of guys run that transfer case and race using 4x4 engaged.
And this is true the auto cases utilize an actuator on the front end that locks it in.
'07 TBSS 1SS
The TB 4x transfer case will bolt right in without any mechanic mods. However, you will have to use a 5.3L ECM tune as our ECM tune doesn't have provisions for the 4x4 ratio change when in 4WD. Mod the tune to your specific engine specs. Tweak the TCM tune. Then you'll have to change out the front passenger shaft housing. Then you'll have to add the 4x4 switch in the dash and maybe a 4x4 module..not sure...then wire it all up. And you'll be good to go! :coolthumb:
07 AWD 3SS
I know its been a kinda dead thread but has anyone done anything yet? Any updates?
2006 TBSS
Old thread but have an update to share for future true 4wd TBSS seekers.
Im gonna try the MP3023 GM tcase. It’s pretty light weight and came from an 08 Silverado 1500 vortec max. Truck also had a 4L70e (exact trans in the TBSS) and also a 6.0L.
This tcase is 100% electronically controlled and looks like it will fit right in. I’ll post an update of what worked and any issues when done.
1 - 20 of 23 Posts
