1 - 10 of 10 Posts
The traction control keeps going off in my 2007 AWD, it goes off sometimes when accelerating from a stop. I brought it to a local repair shop and there was a code for rear ABS sensors, so I had them replaced. Still have the same problem. I have gone back to the shop every week for 4 weeks to see if there are any new code showing up, so far nothing. I replaced the steering wheel sensor 5 days ago (with a GM sensor) and still the same problem. Any idea's?
Thanks, Jim.
Wheel hubs. Replace them all
07 tbss awd
Thanks, Jim.
I have been having the same problem. Has the abs activated while driving? Not sure if your the orignal owner but there are several software updates for the ebcm and other modules. I contacted the dealer yesterday and was told my 07 ss has not had any of the updates since new. Also check the ground wire to the ebcm. If you look at the frame underneath the driver door you'll see it to the left!
Lighter-than-you
delete, delete, delete!
I'm not the original owner, I'm not sure if it has had the software updates. The problem I'm having is when I come to a stop, then accelerate, as soon as I give it gas the stabilitrak goes off, but not all of the time. I can turn it off, but I can still hear the ABS going off sometimes. I have already replaced the rear ABS sensors and the steering wheel sensor, I would hate to pay to have the front hubs replaced with new sensors and find out that I still have the same problem.
Thanks, Jim.
I have had the SS for 11 months and this problem just started, I can't see how it would be a software issue.
2007 3SS AWD
Thanks, Jim.
Got brake fluid?
I had both front hubs replaced yesterday and so far so good. Thanks for everybody's help!
1 - 10 of 10 Posts
