1 - 3 of 3 Posts
2006 TB SS AWD
On my way to work tonight accelerating from a stop caused my stabilitrack to kick in which went away after I hit 20 mph. Coming to a stop the abs and stabilitrack were kicking in causing the truck to shake violently. I pulled fuses 61 and 33 and it seems fine now. Anyone know what could be causing it?
Edit: recent work I just had done on the truck: new front output shaft and seals, new outer tie rods, new front wheel hub, front lower control arm and upper ball joints.
2006 TrailblazerSS
Check your abs sensors. I had the same problem and found that the driver side sensor had come out of it's clip/retainer and started rubbing on the tire. It eventually wore through exposing the copper wire and causing a short. If you have a OBD II scanner that reads abs codes this the best way to diagnose. Good luck!
Sent from my AT300 using Tapatalk
1 - 3 of 3 Posts
