1 - 10 of 10 Posts
Hey guys, so I've been noticing as I'm on the highway and I'm just cruising / hauling something when I come into around 3rd gear or a hill where the motor RPM would go down after a up shift it would start to hesitate or sputter (whatever you want to call it) id just simply give it more gas and it would come out of it. Also I have noticed when I get on it at a higher speed it would do it as well some times. I also had an instance where the check engine light would come on and flash. Any insight to this? I have 184k on it. could it be the fuel pump? since they don't have a filter on the rail, or it being on the pump itself, in the tank.
'07 TbSS 3ss
For those symptoms I would start with the basics, clean your mass airflow sensor, check for any intake leaks as well as plugs & plug wires .
'07 TbSS 3ss
Quick google search
A: The code P0455 means an EVAP system leak detected. As always, check the gas cap first. A common problem in this vehicle is a bad vent control valve. It's installed at the charcoal canister at the back of the car, close to the right rear wheel
Trailblazer 3SS
Have you checked your O2 sensors? Once, I replaced mine it cleared up all the misfire issues I was having and it ran like new.
Discussion Starter · #9 ·
replaced purge valve and vent valve. still doing it. will try o2 sensors next
1 - 10 of 10 Posts
