1 - 9 of 9 Posts
Radiator Home appliance
Simple-engineering/Ron Davis Radiator
Mechanical fan Computer cooling Ventilation fan Electric fan Technology
PCMFORLESS Spal fans
Product Electric fan Machine Mechanical fan Fan
Simple engineering/Ron Davis Radiator with PCMFORLESS Spal Fans
This combo seems to have fixed my cooling problems completely but I am not 100% certain because I haven't been able to run it down the freeway in 113 degree heat yet. I will keep you guys posted.
TrailBlazer SS AWD
Looks nice. What did the whole setup cost?
Discussion Starter · #3 · (Edited)
Too much! 675 for the radiator and I think around 400 for the fans and harness. Plus shipping on the fans. They are well worth it though. Both products are well built.
TBSS 3SS
Would like to hear what temps you are running at now. Kinda curious to the logic of closing off the entire surface of the fan shroud without giving relief or blow through at higher speeds.
I'm sure the larger radiator helps out.
:coolthumb:
Actually the spal setup allows the air to be pushed downward instead of at the motor. Once its crossed through the radiator it's now hot air being blown at the motor.
High and Tight!!!
I was gonna order these fans but the wife killed a tire on the g8 tonight... already have the radiator in and its a damn nice piece.
Sent from my DROID3 using Tapatalk
You won't be dissapointed!
1 - 9 of 9 Posts
