1 - 3 of 3 Posts
is there a lubrication for the piston to help with sticking? I had my avalanche front sticking a while ago. i just replaced with new calipers and pads. i plan on doing pads and rotors on 03 monte and would like to lube pistons if possible while i have everything out.
Discussion Starter · #2 ·
i'm my own stooge. i meant caliper piston.
Hooked on speed
06 Trailblazer SS
No such thing that I know of. Just clean everything up, be sure your seals are seated properly, put a little brake fluid on the face of the seals and put them in the bores. Then
put your dust seals on and gently push the pistons to the bottom of the bore. Put some Permatex Brake Quiet on the back of the pads (or use some Sil-glide or other similar lube) to keep 'em from squeeling.
1 - 3 of 3 Posts
