1 - 4 of 4 Posts
06 Superior Blue
My question is if relocating the swaybar mounts at the rear using some U bolts around the axel housing and a flat pad with two bolt holes so that it would accept normal poly bushings has been done or not?
Long sentence.
06 Superior Blue
I am not saying it will help at all kind of just asking since im a novice.
2006 Red Jewel AWD
There is no need to do this. Since we have aftermarket sway bar options engineered to use your factory mounting location and aftermarket polyurethane bushings readily available, there is no need...
1 - 4 of 4 Posts
