why does the rear view mirror turn blue and then back to clear? and back and forth?
TBlazer07 · Registered TrailblazerSS Joined May 2, 2011 · 156 Posts Discussion Starter • #1 • Jun 27, 2011 why does the rear view mirror turn blue and then back to clear? and back and forth?
HiHoSilver · Premium Member TrailblazerSS Joined Mar 5, 2010 · 2,141 Posts #2 • Jun 27, 2011 (Edited) Auto dim! Cover the little light sensor on the top next time you see it turn blue, it should clear up. Or hold a flashlight up to the sensor and you will see it turn blue.
VettePwr · Premium Member Bet you cant tell Joined Mar 27, 2009 · 6,481 Posts #3 • Jun 27, 2011 auto dim electrochromic mirror
TBlazer07 · Registered TrailblazerSS Joined May 2, 2011 · 156 Posts Discussion Starter • #4 • Jun 27, 2011 VettePwr said: auto dim Click to expand... and whats the point of that?
HiHoSilver · Premium Member TrailblazerSS Joined Mar 5, 2010 · 2,141 Posts #5 • Jun 27, 2011 To reduce glare in your rear view mirror from the car behind you.
VettePwr · Premium Member Bet you cant tell Joined Mar 27, 2009 · 6,481 Posts #6 • Jun 27, 2011 every notice when someone is driving behind you and their lights are annoying. this dims the mirror so the light is not in your face. you can turn it off if it bothers you
