1 - 20 of 24 Posts
2008 Trailblazer SS
Are you referring to the STS Kit?
Build your own, the STS kit is nt that great and you will spend almost as much modding it to make it decent as you will on a used kit. If you would be interested in a big T88 front mount single, let me know. I have one Im selling cheap compared to an STS kit. On vacation til the 22nd, so if you want pics, shoot me a PM, as most are on my phone anyways.
I'm building my own . Don't like the STS so we will be doing a custom set up with twin Garrett turbos if I get a transmission that can hold it all together without breaking the bank
Biggest draw for a front mount vs mid mount is oiling imo...mid mount needs a scavenge system. I like that spot better than in the bay cause underhood temps are going to be ridiculous even wrapped imo.to each their own though. Definitely build your own if you're capable
6.2 silverao
Steve Morris seems to be having pretty good mid mount results.
Discussion Starter #10 (Edited)
The only reason we are putting the turbos under the car is the heat . The guy helping me is GOOD ! He just finished my buddies Camaro and it's a twin rear mount that's pushing 1000 HP and it looks amazing . The trailblazer has tons of room under her so it should look nice.
Or go with the oil less turbos.....Ive actually heard good things about them.
I've spoken with a few shops who are having failures in high boost applications, I'd presume the cooling is inadequate at that point using just the cooling system. I wanted to go with a compturbo for the simplicity but it's a big price tag and my piece of mind is slightly rattled when I can get a comparible turbo and run a scavenge for about half the price ....aerocharger doesn't make anything worth using from what I've seen.
Heres my home made setup. The under hood temps really aren't bad at all. I will tell you one thing. Invest in a 4l80e transmission, because any 4l70e is on borrowed time
As much as I love seeing a turbo sitting in the engine bay I think a mid-mount setup is not all that bad.
This is on a level of it's own but here is one of our members with a TT mid mount setup: http://www.tbssowners.com/forums/heads-cam-intake-manifold-internals/59210-jpracing01-tt-build-up.html
Then you have Nasty Nate's setup they did for a big single: http://www.tbssowners.com/forums/power-adders/91424-upgrade-build-3-0-larger-turbo-4l80e-swap.html
Another member XMONTE has a mid mount setup that hauls some serious ass but not sure he has ever shown build pics. Tune Time has a bad ass white SS with a mid mount that went deep into the 11's spinning like hell.
I really like the ease of fabrication on a 2wd for mid mount as you can run the cold side over to the D/S along the oil pan and up under the P/S pump to an IC or engine bay. Keeping the tubing tucked up tight and not hanging down. I'd go with a COMP turbo (oil-less) and give it hell, they offer turbo's plenty big to spit rods out the side of a block!
If you ever doubt mid mounts just look at the car Vengeance Racing built - Sinister C6, that'll throw any doubt on a mid/rear mount turbo setup right out the window.
Discussion Starter #16
That is a great build. Better than most that I have seen . Drive that thing to bakersfield next weekend.
im not a fan my self of a rear mounted turbo. there is plenty of room in the engine bay too put one. it gets the air there quicker closer to the exhaust ports i don't see any reason to mount one in the rear. not like you're going to hide it when you can hear it when the trucks running
Anyone have any pics or build thread on a mid turbo setup?
I don't want to loose my A/C and it seams like a waste to not use my headers.
1 - 20 of 24 Posts
