1 - 4 of 4 Posts
Ok so I adjusted the rear to 31 and i wanted it a little taller so I tried to adjust it up and now the bags won't inflate, no matter how much I turn the lever. Also if you put weight on the rear the pump won't turn on. I turned the pump on inside and it works, checked all the fuses and they are good. Grrrrrrrr anyone got any suggestions. Also I noticed my battery to be a little weak, would that have anything to do with it?
Sorry but I would replace the bags with coil springs.
Ok thanks guys I was afraid that I was gonna need to replace the bags. Any way that the battery has anything to do with this?
1 - 4 of 4 Posts
