1 - 3 of 3 Posts
TrailblazerSS,
I recently sumped my factory fuel tank. I added on the rail holley 12-600 pump. -8 from sump to pump , than from pump to rails -6. Truck has holley mid rise manifold. When driving normal pressure i have set at 64lbs sometime under wot i see it spike down to 20, run leans than i let off it builds pressure. Happens randomly and only since i sumped it.
How much power are you making and where is the pump mounted? Got a pic of the sump?
TrailblazerSS,
ill take pics in a few.. but sump is on the rear side of the tank, and the pump is mounted on the rail of the truck..
1 - 3 of 3 Posts
