1 - 18 of 18 Posts
Sold
Buy an FSR for about $550 shipped to your door and be done. Excellent quality and perfect fit.
I installed a FSR radiator in my 2007 TBSS. It fits better than the stock radiator, looks great, holds more water, most important --- it keeps my temperatures way down in Houston Texas. Well worth the investment.
95*-- Humidity 88 NO AIR ON it will run between 186-188*
With the air on it runs 10-12* hotter
160* stat, dual spal fans 12" and a 13"
Remote Trans cooler not through radiator
One bottle of water wetter (worth the $11) another 3*
When it is under 80* the truck will run under 180* on the freeway
One of the earlier threads said to use a piece of foam tubing insulation between the radiator and the plastic cover over the space where the hood latch is. That too made a few degrees difference. Cost is about $6.00
Hope this helps
Discussion Starter #12
Hope this helps
my problem is my truck runs hot with a/c on.usually on stop an go traffic i get temps between 217-228 and with the a/c off am usually around 194-205
Can you tell more about the insulation between the radiator and plastic cover and how that brings temperature down?
http://www.tbssowners.com/forums/e-fans-thermostat/27516-cheap-mod-better-cooling-fix-recirculation-issue.html
Willy M'Fn Wonka
07 Trailblazer SS
Ummm.....
Are you sure you should be using an additive in the FSR radiator? I know Ron Davis specifically tells people not to use them (additives) in theirs. :dunno:
06 TrailblazerSS
TrailblazerSS 3SS
So what about going from the dexacool back to green antifreeze in the FSR?
Just doing homework before I pull the trigger....
TrailblazerSS 3SS
I am still under a warranty program and wasn't sure what I was getting into...
Yeah, I sent it alright.
1 - 18 of 18 Posts
