1 - 20 of 20 Posts
outside working on truck trying to figure out why it's running like crap. Started checking plugs and wires. I'm currently running Taylor Thundervolt 50 wires. First 3 on driver's side ohm out at 35 and last one ohmed out at 300. Would this difference cause a problem? Thanks!
Discussion Starter · #2 ·
bump. anyone?
secret squirrel
quite possible. move that plug wire to another plug and see if it still happens...could be a plug itself also.:burp:
I just finished pulling passenger side plugs and wires. I found one wire on that side @ almost 1500 ohms. Went ahead and put new plugs and i am going to put my stock wires back on for now.
That's a helluva difference. I would say it's not helping for sure.
I didn't know if the one at 300 would matter being that the stock wires are almost 800 ohms.
I:iamwithstupid:
I bought msd wires and they ohmed (sp?) higher than the stockers.
I thought the lower the better. Care to teach
Discussion Starter · #14 ·
Well, changed all the plugs and put stock wires back on. Still running like crap. My buddy that usually does all my work for me is down, just had back surgery. So, truck will be sitting for a while until I can tow it somewhere. I don't guess any of you guys live close enough to come fix it for me, eh? :biggrin2:
Discussion Starter · #17 ·
Have you checked coil outputs? Some coils will take a dump.
No, I haven't done anything else to it. Had to come home after work yesterday and do some sheetrock repair in my a/c closet. So, can you tell me how to check them?
@PapaBear- I haven't noticed any codes.
Discussion Starter · #18 ·
Can anyone tell me how to check the coil packs? I have one off the truck now.
07 TrailblazerSS Imp
Well one way would be to move a coil pak around with another but if you measure conductivity on each of them to see if they are uniform also like the wires. A bad one will not conduct the same as a good one.
Discussion Starter · #20 ·
I meant, which pins would i check resistance on. All i could find on google search was for LS1 packs. Not sure if it's the same. But testing them like that, all driver's side were same. About to pull passenger side.
1 - 20 of 20 Posts
