Next up is the motor assembly portion of this project
This bullet will consist of the following
New GM LS9 block that was been prepped with ARP mains and Katech 12mm headstuds . Nice thing about the ls9 block is it has billet main caps, doweled mains, oil squirters and the block itself is a better alloy
I chose to keep the stock stroke and bore, so motor will be a forged 6.2
I picked up a new GM forged lsa crankshaft
Will be using diamond comp series pistons for a SCR of 10.0
Chose to use a set of callies compstar rods
I also picked up new GM rockers to be used with the trunion upgrade
Picked up a set of trickflow CNC ported 225s
Cam that will be used is a 232/240
