1 - 3 of 3 Posts
Saab97x
Problem w/ HID headlights car is actuelly saab 97x 5.3i
When initially purchased 2 years ago the right pass low beam would act up.
Like the only time I could get it pas. Low to come on was to start at high then
All lows and highs come on so I switch to low and then let there be low happens however
The pass. Still goe’s out even after replacing the expensive bulbs &
Yes I never touched the glass part of new bulb.
I believe there is another part that wears that should be replaced in one go so to say of.
So fare just bulbs I’ve read about little about pigtails and blaslasts but have netter done a bulb swap so I’m new and new advice. Thanks
Saab 9-7x
If they are factory HID headlights, there is an ignitor box bolted to the bottom of the headlight assembly. That is most likely your problem if you already put in a new D2RS bulb. But as mentioned , HID are picky about voltage issues so check the power (relay) and ground sides of the circuit.
1 - 3 of 3 Posts
