1 - 20 of 186 Posts
TBSS 3SS
Wiring diagram for 2007 Radio (non-Bose). Thank you.
SS TrailBlaze 06
I am looking for the Tach signal wire. The diagram posted makes it look like it is pin 25/121 WHT.
I have a new MSD Timing Twister that needs a Tach signal to work. It allows you to adjust timing at the track or for the street by adding timing or taking timing out with just a twixt of a screw under the hood it even has a wire for boost or nitrous that you can adjust how much timing to pull when nitrous is activated. I want to make sure I have the actual Tach signal so as not to mess things up. I am a nitrous junkie so this will keep me safe. Thanks
· Registered
E-Brake/ABS Light Won't Go Off!
Blaze, I changed out all four rotors and replaced front brake lines to stainless steel, greased the calipers, bled the brakes from farthest to nearest, checked resorvoir. Brakes work fine and ebrake works also, however my ABS LIGHT and EBRAKE LIGHT won't go off. I tried disconnecting the battery a whole day,pulling fuses and nothing is working ------ WTF!!!!!!!!!!!!!!!!!!!!!!!!!
My friend said to bring it to his shop tomorrow and he will just clear the codes! What's your thoughts on this problem? HELP BLAZE !!!!!!!!!!!!!!
Black 2006 SS
Hey Blazen,
I'm adding a set of LED taillights and looking at adding in a taillight converter to tie the brake lights and turn signals together and also a load equalizer on my turn signals too. Can you tell me where the taillight wiring harness is and how to get to them or where to find a wiring diagram?
Thanks and God Bless!
Scott
1 - 20 of 186 Posts
