1 - 13 of 13 Posts
when i got out of work tonight i fired up the ss and heard a rattle right when i fired it up! i revved it a little, and the rattle was still there, but only when i revved it! not at idle or gradual rpm increase! then i went to leave and as i went forward it sounded like an exhaust tick but went away as the engine warmed up! my CEL isn't on! and it seems to be running the same! 52,000 miles! any suggestions?
Doubt it's a cat if performance hasn't changed or you can't smell it. I would crawl under and look for anything loose near the exhaust, maybe tap muffler and the cats with a hammer to see if you can hear anything rattling.
Passenger side cat was the culprit when I had this problem. It sounded like bolts in a coffee can that got louder at higher RPMs.
Call da amber lamps
Take a rubber mallet and tap the cats. You should be able to hear it if it's one of the cats. You're covered under emmissions warranty still.
TrailBlazer SS
I just had the same problem...took it to the dealer and the cats needed replaced
i guess i should've posted that i got it fixed! it was my drivers side cat! i drove it about 200 more miles and the damn catalyst turned sideways inside, and sent the ss into limp mode! i now have the magnaflow catted y pipe! all is good!
btw the rubber mallet trick didnt work for me!
How is all good when it throws a code?
How much did the Magnaflow pipe run you? I looked on their site and kinda jaw dropped at the MSRP. Are they high flows or OEM replacement?
Discussion Starter #12 (Edited)
:fu: yes i do still get a CEL, im getting a catalyst efficiency below threshold on both banks! its happening because of the cats being HIGH FLOW and being UNTUNED!
Discussion Starter #13
$550 from summit! they're high flows!
1 - 13 of 13 Posts
