1 - 10 of 10 Posts
I installed HID kit about 6 months ago all of a sudden they went out so I unhooked the ballast and put my meter on the factory harness I am only getting 1.0 v I checked all my fuses and they are fine.
What could be causing this problem? I also put in the factory bulb as well just in case with no success.
any help would be greatly appreciated, Mike
I am driving around with my high beams now at night lol
Do you have DRL killer? But it's probably the headlight relay, GM calls it headlight driver module.
Hit me up if you need any help with it, I'm here in Jax also. If you want to run it by the shop tomorrow I can check it for you, just let me know.
That would be it the headlight relay or headlight driver module
there is a 15a fuse that blew on mine labeled HDM in the engine fuse block. Mine went out while in Dallas and I was without headlights in 6 lanes of traffic!
07 TrailblazerSS Imp
Yea but we had ya covered nose to tail, Jesse, at least thru most of that driving.
:cheers1:
dude you guys are so freaking awesome I will give that a shot thanks
thanks gentlemen I switched over the fan relay and the lights work so it was the relay thanks again. Went to autozone and bought a new relay $40 bucks
yeah thanks man
1 - 10 of 10 Posts
