1 - 17 of 17 Posts
'07 3SS 2WD
My TBSS is currently under the knife for a 402 build. Bent a valve...
Are there other options for a relocated pick up besides PCMoNC? Do the the up graded baffle kits suffice in place of the tube kit?
'07 3SS 2WD
idid new pan kit about 400,leftcoast ac billet bracket 100, i think. still stock crossmember with little trim in flter area. also a oil drain valve to connect hose for easy drain.
Have a link for the kits?
'07 3SS 2WD
Discussion Starter · #10 ·
'07 3SS 2WD
Discussion Starter · #11 ·
Left Coast recently moved to my area too...
'07 3SS 2WD
Do you happen to have any pics?
I'm not doing the work, and the shop that is do it is about 5 hours away.
Chatting with the maker of the oil baffles, he's sold over 2000 of them. That's no small amount. It's cheap insurance.
Of course, you can just go to a better pan in general too. It all depends on budget and goals.
2007 TBSS
I did the all the above including front and rear chassis stiffeners. (also 402 stroker TBSS 2WD)
Corvette pan, dipstick
LC32 crossmember
Simple Engineering chassis pieces (compliment front crossmember amd stiffens/squares frame)
Just looked -
——LeftCoast32 website crossmember shows out of stock
Simple Engineering
Simple Emgoneering website has
——Lc32 crossmember
——Front chassis stiffening plate (I did powder coated black)
—— 4 bolt Rear crossmember
The PCM of NC oil pickup tube relocation kit is the best option if you have AWD TBSS did it to mine about 4 years ago when I did a rebuild and power mods Steel crank H-beam rods heads cam Etc., it has worked flawless best Money I ever spent
'07 3SS 2WD
Discussion Starter · #17 ·
I'm 2wd. Looking at the Vette pan option.
1 - 17 of 17 Posts
